Quarter Window Outer WeatherStrip - MSA
New-to-240z
So, I bought MSA's full Weatherstrip package for the 240Z. I'm replacing the 1/4 window gaskets and everything has gone smooth so far, except for one thing . . . the outer gasket for the window is WAY TO SHORT. If I were to STREATCH the hell out of it, it might actually fit, but I don't think weatherstrip cement or adhesive will hold it there. Has anyone else noticed this? I am amazed at this! so far, everything else has been fitting with no issues. Anyone have any idea on what is happening? I'll take some pictures today when I get home.
I think you a talking about INNER seal. I had the same problem, but just used a little soapy water and it was much easier. I have the glass seated correctly in the inner seal, along with the screw holes that hold the actual frame together. But, I'm talking about the OUTER gasket that goes around the quarter window frame that presses against the body of the Z.
I was talking about the outer seal. The inner can be tricky but I've had a lot more trouble with the outer seal. I get to try that again in a couple months when I finish my new race car. If I get a chance I'll measure the outer seals that I have tonight.
Chuck
Post some pics. Otherwise you're expecting everyone to presume that you've assumed which weatherstrip goes where. You may be spot on, but one of the weatherstrips being ~short~ in one of their kits is totally unheard of. After years of doing this, that they got one short, as opposed to your having misconstrued the fit or misidentified it's use... which one would you think is more likely.
I'm not saying that they've never made a mistake, just that the odds aren't there.
FWIW
E
nope, you were right E. :-( I went back and found that I i got them mixed up. It was my fault, I should have called it a night instead of getting upset and trying and trying to get it to fit. Went and looked the next day and BAM. Found the right part. :( This one is actually a little long now (like an extra 0.5 - 1.0" so I'll be trimming it up.
E, thanks for the helpful words. I really do appreciate it.
I would also REALLY appreciate it if you could give me some help with installing the quarter window. I had one hell of a time getting the gasket to stay in place and now I can't for the life of me, figure out why I can't get them to go back in. I tried installing them without the gasket, and they fit perfectly. Any tips on getting them back in place? They're holding me up from moving forward with the rest of the door gasket.
Do I even have it on right?
Edited by New-to-240z
You have it on right. The short leg goes towards the inside of the car.
As far as installation, make sure you have the proper screws that screw into the tabs on the window frame, if necessary run a thread chaser to ensure that you're not fighting a bit of old rust/corrosion trying to get the screw started or tightened.
Next, use a lubricant all the way around the gasket and opening. I personally prefer food grade silicone, but then I have a neighbor who works / services food equipment. Dishwashing detergent can dry out if you take too long, but if you water it down it can stay slippery for a good long while. I wouldn't use an oil nor grease, they'll attack your gasket / paint.
Now comes the fun. Ideally you should have a friend help you hold and press on the FRAME of the glass (not the glass) and press not only on the frame IN towards the interior, but also on the front part of the frame towards the BACK of the vehicle (insert the wedge so to speak). When he gets it into place, you should be ab le to use one hand to push the rearmost apex of the window IN so that you can get the screw started. Start the screw and only go two or three turns, don't tighten it at this point. All you want to do is get it started.
Once the rear most is started, address the next one, whether above or below and do the same.... just get the screw started.
Once you have all the screws/washers started, then start tightening down EVENLY and keep an eye on the whole assembly. You do NOT want to snap a screw nor strip it.
The reason you're having a hard time is that you're dealing with new rubber. If it were going on easily, it wouldn't be making a good seal.
Hope this helps
E
All of the above that EScanlon says !!!!
and here is a nice trick to add:
I used longer new screws (actually bolts with same threads) to pull the window in from farther out. Once the 4 bolts have it pulled in, you can change them out with the original screws one at a time.
You can do it in several steps if you want with very long, then medium, then short bolts.
The long bolts make alignment much easier than with the tiny original screws
Now that is a good idea!! I'll try that out next. I'll grab some dishwasher soap, a spray bottle, and go to town on them. As a side note, I just had the car painted about 3 weeks ago. Do I have to worry about the dishwasher soap? Should I bite the bullet and get some food grade silicone?
Would this work . . ?
Petrol-Gel Lubricant, 4 oz Tube
  • Who's Online   2 Members, 0 Anonymous, 746 Guests (See full list)
