Posted January 29, 201312 yr comment_413438 Hi guys, I am working on replacing my frame rails from the firewall forward. Since the tension rod buckets are mounted to these I will have to either reuse my old ones or get new ones. Does anyone offer these? I'd rather not reuse my old ones as one was from a 280 and the other from a 240...they are different. Not to mention I have caused significant damage to the 240 one when i was trying to remove it without destroying the fenderwell. If you have any ideas or a spare set laying around somewhere I'd be interested to hear about it. Most likely I'll end up fabricating a new set thou. Thanks Link to comment https://www.classiczcars.com/forums/topic/45543-tension-rod-bucket-replacement/ Share on other sites More sharing options...
January 30, 201312 yr comment_413470 theczchone, you might what to build your own, I have not seen any new. It's kind of a box with out a top right ? 2 sides and a bottom. I do not have my Z here but you should be able to cut cardboard out and piece them togather I guess....How think are they ? Link to comment https://www.classiczcars.com/forums/topic/45543-tension-rod-bucket-replacement/#findComment-413470 Share on other sites More sharing options...
January 30, 201312 yr Author comment_413475 They are 4mm thick. There is a fabrication shop here close so I might see if he'd make them for me and how much he'd charge. I will make a proper engineering drawing for the part and most likely redesign the whole thing, because the original part is stamped metal. Edited January 30, 201312 yr by theczechone Link to comment https://www.classiczcars.com/forums/topic/45543-tension-rod-bucket-replacement/#findComment-413475 Share on other sites More sharing options...
April 6, 201312 yr Author comment_419744 Does anyone have a 240z parts car they would be willing to cut this out for me? I need the passenger side tension rod bucket. If you can help me, please let me know, I missing this part on my car. Just let me know how much. Thanks Link to comment https://www.classiczcars.com/forums/topic/45543-tension-rod-bucket-replacement/#findComment-419744 Share on other sites More sharing options...
April 7, 201312 yr comment_419769 Yup, I have a fresh shell just in that has good T-rod pockets. Love to chop them out for ya. Might be a few days. $40 + shipping? Link to comment https://www.classiczcars.com/forums/topic/45543-tension-rod-bucket-replacement/#findComment-419769 Share on other sites More sharing options...
