Runs Rough After Sitting 10-15 mins...
NiiChan GT-R
Fastwomen: okay first let me say sorry for taking so long to get back with info. I did order the one from Sam and installed it this morning. Went back later, 45 minutes, and it was still holding pressure. After about 3 hours I rechecked and the pressure had leaked down to "0"! Not sure what is going on here. So what I'm going to attempt to do is pressurize the system and pull the fuel line from the fuel filter "out"(that is where I installed the check valve) and see if it bleeds back. If it does then it's the check valve. If not then I have a leaky injector, which are new! Either way I'm not happy!
NiiChan: I was having the same problem and was able to correct it (time will tell) by adjusting the air bypass screw in my AFM 1/2 turn clockwise which meant I was just a little too lean.
I will get back when I have results of the test I want to run next.
  • Who's Online   2 Members, 0 Anonymous, 782 Guests (See full list)
