February 14, 201312 yr Author comment_414977 Strange there is no factory engine paint code for Datsun to be found, like they just used some random paint color from the shelve.. I can order cans from the US, but the shipping costs are the price of 2 cans, so I'd rather get some paint locally..mmm Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-414977 Share on other sites More sharing options...
February 14, 201312 yr comment_414981 Bart, If you find a local supplier that can fill spray packs. PM me. To mix one can would cost a lot. Maybe we can bulk buy and get a discount? Im in the same boat as you. All that shipping and taxes its getting ridiculous. At this rate ill spend €5000 on restoring and €10,000 on shipping and taxes.Chas Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-414981 Share on other sites More sharing options...
February 15, 201312 yr Author comment_415063 Bart, If you find a local supplier that can fill spray packs. PM me. To mix one can would cost a lot. Maybe we can bulk buy and get a discount? Im in the same boat as you. All that shipping and taxes its getting ridiculous. At this rate ill spend €5000 on restoring and €10,000 on shipping and taxes.ChasIf you have a piece that contains the original color let me know, I will take it to the paint shop to examine the color. We can bulk, but I only need 2 cans or so..Bart Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-415063 Share on other sites More sharing options...
February 15, 201312 yr comment_415068 Do you guys ever use the SEARCH function? We've discussed all this many times before. The original colour had its roots in the Austin-Nissan tie up of the 1950s.The colour is still listed on the 'British Standard' database as B.S. 18C39, with HMG ( Her Majesty's Government ) Glidden number GL31557, and Glidden number name 'Dolphin Blue'. I think a Netherlands-based paint supplier should be able to cross-reference those codes. Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-415068 Share on other sites More sharing options...
February 16, 201312 yr Author comment_415156 Do you guys ever use the SEARCH function? We've discussed all this many times before. The original colour had its roots in the Austin-Nissan tie up of the 1950s.The colour is still listed on the 'British Standard' database as B.S. 18C39, with HMG ( Her Majesty's Government ) Glidden number GL31557, and Glidden number name 'Dolphin Blue'. I think a Netherlands-based paint supplier should be able to cross-reference those codes.So I need to give them BS18C39, correct? Search Colour - 18 C 39 Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-415156 Share on other sites More sharing options...
February 16, 201312 yr comment_415157 So I need to give them BS18C39, correct? Search Colour - 18 C 39The website says "The colours depicted are also for guidance only. The displayed colour will depend on your monitor and browser" I hope so, it looks a lot darker than what my engine is painted.Chas Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-415157 Share on other sites More sharing options...
February 16, 201312 yr Author comment_415169 I will let them make a rattle can, and spray it on to my engine, see what it does. This must be the right color then. Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-415169 Share on other sites More sharing options...
April 14, 201312 yr comment_420492 Do you guys ever use the SEARCH function? We've discussed all this many times before. The original colour had its roots in the Austin-Nissan tie up of the 1950s. The colour is still listed on the 'British Standard' database as B.S. 18C39, with HMG ( Her Majesty's Government ) Glidden number GL31557, and Glidden number name 'Dolphin Blue'. I think a Netherlands-based paint supplier should be able to cross-reference those codes. Worst way to start a reply! I use the search first all the time and RARELY get the answer I seek. Today I searched Engine Color, Block Paint and Engine Paint and I got this thread - and a few others. At least after you "made your point" you - ironically - gave us the information we needed. Thanks. But if you're not doing a concours restoration, Dupli-Color's GM Engine Blue is very close..... Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-420492 Share on other sites More sharing options...
April 14, 201312 yr comment_420508 Worst way to start a reply! Not at all. I think it was perfectly valid. It's something we have discussed many times in the past. You managed to find this thread a couple of months after the last reply, didn't you? At least after you "made your point" you - ironically - gave us the information we needed. Thanks.Nothing 'ironic' about it at all. If I have the answer I'll usually give it. Stop complaining.Dupli-Color's GM Engine Blue is very close....Spraying a Nissan engine block in a GM colour might be ironic, though... Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-420508 Share on other sites More sharing options...
April 14, 201312 yr Author comment_420514 Well I took the code HS30-H gave me to various paints shops, but strangly they couldn't convert the paint code.. so the only will be ordering from the states this summer then. I can't paint the block now anyhow, need to do in the summer months. Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-420514 Share on other sites More sharing options...
April 14, 201312 yr comment_420519 Well I took the code HS30-H gave me to various paints shops, but strangly they couldn't convert the paint code.I don't know why not. My local automotive paint supplier can cross-match across BS, Glidden and RAL ( the European Standard ) paint codes, as well as custom mix and match to sample. Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-420519 Share on other sites More sharing options...
April 14, 201312 yr comment_420522 I was searching for a hood vent yesterday and ran across this listingDatsun Engine True Blue/Green Spray Can Paint Link to comment https://www.classiczcars.com/forums/topic/45590-original-blue-engine-paint-colorcode/?&page=2#findComment-420522 Share on other sites More sharing options...
