Radio shack offers a "pigtail" that has a couple of "power ports" on them .They are not able to handle a lighter due to the heat,but they are the ends you require.You could have one of these hooked up,no problem.I wired them up for my wife and ran them under the console so there was enough slack to do what was needed without having the wires in your way hanging from the dash.A caution.When you connect the power source be sure if you want power when the car is off.A P.C. will drain your battery in less than a day should you leave it on in your car.It sucks on monday when both your pc and your car are dead.It didn' t take me but a dozen or so time's to figure that out!!:stupid: Have fun!! Daniel
https://www.classiczcars.com/forums/topic/4562-smoken/#findComment-25628
