240K - C110 Wheel offset w/ flares..
KID-K
you will get 9j front and 10j rear easy, i have seen 10/12j but has alot of camber, offset would be between 0 to -40ish front or back but also varies on disk type. Also comes down to tyre and if you want to stretch, if you don't want stretch run 7's-8's
Looks like you could get away with anything in the 0 to -19 size without an issue
thanks guys -19 silly me, I thought they were 19inch.....sorry.........
if I had 15 inch wheels x 8 inch with 0 offset, Would these work?
