Considering it was a gloried milk jug originally, I wouldn't hold out much hope. If your to do list is that short, BlackDragonAuto has a universal windshield washer kit that looks identical to my series I unit for $20. At that price, there's no reason to let smashed bug win.
On a somewhat related note, does anyone know of a source for motors that will fit on the windshield water bottle? The one on mine is corroded solid. I had a spare tank from a roadster but the motor on that one is in the same condition.
I have one that I took off of my 74 when I put in a new washer bottle, but I think I took off the wires. You'd have to solder wires onto it.
Trico 11-601
check the thread here:
http://www.classiczcars.com/forums/misc-s30/36207-replacement-washer-fluid-pump-how.html
I read a trick for cleaning yellowed plastic. Immerse in peroxide and expose to sunlight for a day or two. Not sure how well it works or what exact type of plastic but it may be worth trying.
Here is the magic mix.... I bet it will also work nicely on the door strike bumpers for show cars:
Retr0Bright Restores Yellowed Vintage Plastic to Factory Fresh
That's a pretty big jar you'll need to immerse the entire washer reservoir- probably a two-gallon one. I suppose you could just do one side at a time? I saw a short YouTube video on this, and the person left the plastic part only party-immersed in the solution, and could see the line where the liquid was.
I wonder if Meguiar's or some company like that has a product to clear up the UHMW plastics.
Edited by TomoHawk
After a little research.... One person use Coffee grounds & water. the grounds were supposed to be a kind of abrasive that didn't dissolve, like salt or sodium bicarbonate.
Edited by TomoHawk
