Posted February 15, 201312 yr comment_415098 I have my steering column out of the car. I want to check everything out. Grease, etc. In the manual it says bearings can be serviced where the circlip is. The bottom column slid right out. Up top where the circlip is (steering wheel end) seems to be stuck. I don't want to force anything. Any info or help? 71 240Z Yhank you very much, TimsZ Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/ Share on other sites More sharing options...
February 16, 201312 yr comment_415122 I don't think you're "really" supposed to mess with it. That said: Start with this: Slide the mount off exposing three screws that hold upper half to lower half: Take out three screws and separate upper and lower: This is the steering wheel end with retainer clip still installed: Pull off the steering wheel taper shoes and the retainer clip: Once you remove the retainer clip, the upper shaft comes out the bottom end of the housing. The spring will probably push it out, but it might require some gentle persuasion in addition to the spring: Tap the bearings out of the housing if you dare. There is one at the top and one at the bottom: Bearing disassembled: There are thirty balls in the bearings so you can count what you have to make sure you didn't drop any: Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-415122 Share on other sites More sharing options...
February 16, 201312 yr comment_415140 That's definitely very good information. I might not be the only one with shaft play in my steering column.Thanks! Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-415140 Share on other sites More sharing options...
February 16, 201312 yr comment_415159 One thing that I forgot to point out is that the process and pics above are for 240 only. In 74 they changed the column design and I've not taken one of the newer "steel ball" styles apart.I'd love to mess with a new one (since that's what I have in my 77) but since the only one I have is on my car, I can't take risks with it without a backup plan. Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-415159 Share on other sites More sharing options...
February 17, 201312 yr Author comment_415187 Thank you very much. I didn't know the middle part came apart. TimsZ Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-415187 Share on other sites More sharing options...
November 30, 201410 yr comment_459558 Captain O - Thank you for the detailed pics. I've got the steering column out of my 240Z right now and the top bearing is noisy. I'm going to get a replacement bearing from Nissan, but how did you get the top bearing out? Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459558 Share on other sites More sharing options...
December 1, 201410 yr comment_459595 Once I had the shaft out of the center, I tapped the bearings out using a long wood or brass rod tapping from the far end. The bearings are press fits into the column tube, but it's not a very tight press. Work your way around the perimeter tapping gently and you can walk them out. Then once you get the bearing assy out, you can pop the retaining ring and lose the balls. So new bearings still available from Nissan? Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459595 Share on other sites More sharing options...
December 1, 201410 yr comment_459611 Thanks Cap'n O! I was hoping I could get the bearings from Nissan, but no. After some research, I believe these 1/8" ball bearings are the right replacements: http://www.mcmaster.com/#9642k29/=uu16ls My top bearing was dry and I believe the ball bearings are now out of round. Even after adding grease, the top bearing is still noisy. I'll let you know how it works out. Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459611 Share on other sites More sharing options...
December 1, 201410 yr comment_459614 I wouldn't hold out great expectation that dropping generic balls into an existing race would be trouble free. I also wouldn't hold out great hope that the balls in the original bearings are imperial dimensioned either. I haven't measured one, but I would expect them to be metric. I still have the bearings that I pulled out of that steering column. Most of the rest of the column is gone by now, but I saved the bearings for just such an occasion. I was planning to put one of the two into the top of my 280 column, but I'll still have one spare after doing that and you're welcome to it if you wish. So I'll measure the balls from my bearings and let you know what size they are, and failing being able to find a suitable replacement, I'll hook you up. You gonna be at Carlisle again this spring? Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459614 Share on other sites More sharing options...
December 1, 201410 yr comment_459615 Good point wrt metric vs imperial. 1/8" would be 3.175mm. I'd appreciate it if you could measure the ball bearings and let me know the size. McMaster-Carr also has metric ball bearings in 3 and 3.5mm sizes (+-0.0025mm). http://www.mcmaster.com/#metric-stainless-steel-balls/=uu42gv If my ball bearing swap doesn't work, I'll take you up on the bearing offer. I'd like to attend Carlisle again in the spring, but it depends on work. Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459615 Share on other sites More sharing options...
December 1, 201410 yr comment_459620 FYI: The Carlisle Import & Kit Nationals will be featuring Japanese cars next year. We will be there selling parts and probably showing some Datsuns. Chuck Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459620 Share on other sites More sharing options...
December 1, 201410 yr comment_459622 Well I'll be... I just measured a couple of the balls and came up with my (uncalibrated) mic in the shop and came up with just under .1250 for the ball diameter. So it seems they are 1/8 and NOT metric. I won't attest to the sub thousandth accuracy of what I measured, but it's clear that they are NOT 3mm or 3.5mm. One of the things I noticed when messing with these bearings a while ago is that they are not packed with a full complement of balls. I bet you could get at least one additional one ball and maybe more packed into the race if you wanted to. I assume Datsun left it a little loose because they didn't want drag there and it's a low stress/speed application. But the point is, if you get some 1/8 balls from McMaster and they're a tiny bit bigger than stock, they should still work. So it sounds like a plan! Order a baggie and let us know how it turns out! Link to comment https://www.classiczcars.com/forums/topic/45715-steering-column-help/#findComment-459622 Share on other sites More sharing options...
