Naaa. Don't take anything apart if you got it running. All of the manuals say that when you look down into the distributor hole the small half moon should be at the front when at #1TDC, but I guess you could put it wherever you want as long as you adjust the spark plug wires to make up for it.
Out of curiosity, now that it runs... Can you take a pic of the engine bay showing the distributor and wires?
Nothing jumps out at me as being out of the ordinary. I was half expecting to see the #1 wire on the rear side of the cap back by the carbs.
I can't really explain how yours works fine with the small half moon to the rear when my car (and all the service manuals) say to put the small half moon to the front, but whatever works.
Only other thought I have is that what you were thinking was TDC on #1 was actually TDC for #6. I remember you said that you pulled the valve cover to verify that you were, in fact, on TDC#1, so other than that, I got nuthin'. :)
Anyway, like I said, whatever works. If it's running fine now, then I say don't mess with success, right? Unless someone else has a theory...
Great pics by the way.
