On my 76 280z 2+2, how do I get the rear quarter panel emblems off?
I thought I'd ask for advice before I try to just pry them off and break them or something.
Thanks
Gary
On 240z, you just need to pull them off nicely. I do it by only using my fingers. There're some spring loaded sleeves around the pins holding the emblem on the car.
Yep, barrel clips are on the pins on the back of the emblem. A little spray lube can usually help to ease them out. Try to get a thin plastic pry tool to lever the emblem away from the body.
