Posted February 22, 201312 yr comment_415822 Struts & springs /w poly bump stops are new from last year.Here is the list so far. I'm thinking of doing the wheel bearings as well but haven't quite decided. Am I missing anything which could be added? (bushings will be rubber as our streets are pretty rough up here)Hawk HPS brake padsEarl's SS brake linesBrake rotorsCaliper rebuild kitTension Rod kit from MSAFront Tension Rod Bushing (2)Front Control Arm Bushing (2)Front Sway Bar End Link Bushing (8)Front Sway Bar to Frame Bushing (2)Rack Bushing Drivers Side (1)Rack Bushing Passengers Side (1)Steering Column Coupler (1)Sway bar end linksStrut bearingsTie rod endBall joints Edited February 22, 201312 yr by Ptero Link to comment https://www.classiczcars.com/forums/topic/45793-refreshing-front-end-suspension-brakes-am-i-missing-anything/ Share on other sites More sharing options...
February 22, 201312 yr comment_415841 Looks like a good list. Unless you replaced previously, you could replace the steering knuckle to strut assembly o-ring.Motorsport! O-Ring, Steering Knuckle To Strut Assembly, 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z PartsI would also evaluate the steering rack boots and have those on hand if they are dry / cracking.Might as well do the wheel bearings and seals while you have it all apart.If your master cylinder looks 100 years old, you may want to replace it while you are doing the caliper rebuild. Link to comment https://www.classiczcars.com/forums/topic/45793-refreshing-front-end-suspension-brakes-am-i-missing-anything/#findComment-415841 Share on other sites More sharing options...
February 23, 201312 yr comment_415871 If you doing the strut bearings you might want to check the strut boots. They would be probably in worse condition than the steering rack boots. Motorsport! Shock Boot, 74-78 260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts If you do anything to the master cylinder, replace it. I think you can still get the rubber cup kits, but at $95 its not worth the hassle. Black Dragon Automotive - Parts & Accessories for Datsun 240Z, 260Z, 280Z, 280ZX & Mazda RX7 I would also clean the brake switch and the proportioning valve. They get pretty gummed up over the years and probably not working like they should. The cups in the Proportioning valve are NLA so be carefull dismantling it. You can get the o-rings easy enough. Just make sure the o-rings are made of EPDM rubber material. Dont use Viton or NBR rubber. It doesnt go good with brake fluid. Link to comment https://www.classiczcars.com/forums/topic/45793-refreshing-front-end-suspension-brakes-am-i-missing-anything/#findComment-415871 Share on other sites More sharing options...
February 24, 201312 yr Author comment_416003 jonathanrussell said: Looks like a good list. Unless you replaced previously, you could replace the steering knuckle to strut assembly o-ring.Motorsport! O-Ring, Steering Knuckle To Strut Assembly, 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts I would also evaluate the steering rack boots and have those on hand if they are dry / cracking. Might as well do the wheel bearings and seals while you have it all apart. If your master cylinder looks 100 years old, you may want to replace it while you are doing the caliper rebuild. I hadn't seen the steering knuckle o-ring until today when I ripped it off by accident. So good idea on replacing it! Master cylinder is on a future list when I start getting into the engine bay a bit more. Link to comment https://www.classiczcars.com/forums/topic/45793-refreshing-front-end-suspension-brakes-am-i-missing-anything/#findComment-416003 Share on other sites More sharing options...
