Posted February 5, 200322 yr comment_25738 ey all,just wonderin out of intrest,wat mods would it take to get 300hp out of a stock zx turbo engine in a 240z??? is efi the only way to go in this senario? or could one use somthing like a tripple 45ml weber set up? how much cash should i be looking at for putting out this kind of horspower. thanksjames Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/ Share on other sites More sharing options...
February 5, 200322 yr comment_25746 We talking 280zx turbo, or 300zx turbo? Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25746 Share on other sites More sharing options...
February 5, 200322 yr comment_25765 If you are talking about just using the turbo engine (without the turbo), write to Dave Jarmen of DJ Road and Race: david.jarman@bt.com He's building me an engine and I've seen the rolling road print outs of similar spec engines and it's not far from 300 bhp ! Photo (I hope) enclosed ! Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25765 Share on other sites More sharing options...
February 5, 200322 yr comment_25779 it would be a little hard and really expensive to get 300 hp out of an N/A straight six application, yes you could use webers but when when fuel injection is so much better.on that same note the price you would pay for a set of webers would almost buy you a goos stand alone fuel management system from someone like SDS.now if you were to drop a 2.8 turbo motor into your lil 240, 300 hp would not be hard to reach at all. Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25779 Share on other sites More sharing options...
February 6, 200322 yr Author comment_25837 hi againit would be from a 280zx and what are the type of mods that you would recomend to push this kinda bhp outa tha stock engine.thanxjames Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25837 Share on other sites More sharing options...
February 6, 200322 yr Author comment_25838 ohh yer i do mean stock 280zx turbo engine Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25838 Share on other sites More sharing options...
February 6, 200322 yr comment_25874 I'm not a turbo guy, but I'll venture a few guesses: T3/T4 turbo, bigger injectors, intercooler, boost controller, fuel management system. 300hp shouldn't be difficult at all, I know of one making 350rwhp on the stock bottom end at HybridZ.org. Forget about triple carbs. FI is the ONLY way to go for a turbo. Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25874 Share on other sites More sharing options...
February 6, 200322 yr comment_25886 Go to this site, read, learn and be enlightened!!your quest is but pultry to the gains possible:D Http://www.angelfire.com/extreme/280zxt oh did i also mention before he changed from this set up he was at 450 RWHP in a daily driver:o Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-25886 Share on other sites More sharing options...
April 27, 200321 yr comment_35331 buy a big bore kit from motorsport auto for 1800 and build a 3.1 stroker turbo motor with it LEAVE IT Fuel injected a t4 turbo upgrade intercooler boost controller blow off valve and upgrade your fuel injectors BUT DONT OVER BOOST YOUR TURBO Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-35331 Share on other sites More sharing options...
April 27, 200321 yr comment_35335 For me a 300hp L series is exactly that 83/280zx turbo with full drive train, high flow TO4, big intercooler, after market injection and management system.But the real problem here is the prep of a classic Z to handle the power increase safely BIG BUCKS.My 2cSteve:classic: Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-35335 Share on other sites More sharing options...
April 28, 200321 yr comment_35402 You can get 300HP at the crank easy with the stock L28ET long block. There are people out there pushing over 400HP with a junkyard motor. Of course to do this, you need a bigger turbo, bigger injectors, intercooling, aftermarket engine management, and lot of dyno time.My 240 has a 83' turbo long block, and the following:36lb/hr injectorsspearco intercooler60mm throttle bodyprogramable engine managementcrank triggered ignitionT4b/T3 turbocustom downpipeetc., etc.Over the next month or so I'll be getting it back on the dyno. It's incredibly fast. I figure it's in the 300HP ball park, but I won't know for sure until it's fine tuned on the dyno.As far as the drivetrain handling it, no problem. I figure my car is putting around 270-300ft-lbs to the wheels, and the 280Z 5speed is holding up fine. I'm running a 3.7:1 R200 LSD, and it shows know signs of failure. I run this car in autocrosses and in 2 to 3 track events a year (it gets driven hard).It will roast both tires in second gear easily.Pete Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-35402 Share on other sites More sharing options...
April 28, 200321 yr comment_35408 Just my 2 cents mind you,but just drop a mild V-8 in that,its cheaper and I believe more reliable.Ive gone 525hp with no lag or overboost.he,he.Peace Link to comment https://www.classiczcars.com/forums/topic/4581-300hp/#findComment-35408 Share on other sites More sharing options...
