Posted February 24, 201312 yr comment_415989 Installing new side seals. Nissan part. Do two lips face the block or the crankshaft? These are one piece seals from Nissan. Thanks Link to comment https://www.classiczcars.com/forums/topic/45813-rear-main-side-seals/ Share on other sites More sharing options...
February 24, 201312 yr comment_416011 Tom Monroe "How to Rebuild your L motor" pp.118, "Oil the side seals and insert them into their grooves with the lips pointing toward the block." Link to comment https://www.classiczcars.com/forums/topic/45813-rear-main-side-seals/#findComment-416011 Share on other sites More sharing options...
February 24, 201312 yr Author comment_416028 Yep, I read that but then it goes on to talk about inserting the "nails" which is a different type seal. I think you and they are right though, the lips should probably point to the block. Thanks Link to comment https://www.classiczcars.com/forums/topic/45813-rear-main-side-seals/#findComment-416028 Share on other sites More sharing options...
