Posted February 26, 201312 yr comment_416211 Didn't know where else to post this, so like the title says, i don't wanna over pay.Any help?Thanks! Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/ Share on other sites More sharing options...
February 26, 201312 yr comment_416218 Since a lot of people replace it with either an r-200 or lower geared r-180, they should be giving them away. If I were to go back to the 3.36 r-180, I wouldn't pay over $50 and that for me is a little high. That is still high for a more desirable 3.9 or 4.11 r-180. Edited February 26, 201312 yr by Darrel Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416218 Share on other sites More sharing options...
February 26, 201312 yr comment_416228 Realistic you will be paying $100-$300 for a diff in good shape and you still have to change out some seals. Be sure to research your gear ratio - just when you think you want a 3:36 you find out a 3:54 has better get up and go..........do your homework. It also depends on what transmission you are running - a 4 speed with a 3:54 is a great combo / a 5 speed with a 3.9 or a 4:11 is not bad either. Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416228 Share on other sites More sharing options...
February 26, 201312 yr comment_416230 Around here - a good used R180 3.36 will be $175.00 - if it's been cleaned up, with new rear cover seal, and you can easily remove the drain and fill plugs - $225.00 would not be out of the question.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416230 Share on other sites More sharing options...
February 26, 201312 yr comment_416266 I'm selling my good 3.36 R180 for $50... Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416266 Share on other sites More sharing options...
February 26, 201312 yr comment_416276 Here in SoCal I just scrapped a half a dozen 3:36 R180s. 12 cents a pound. Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416276 Share on other sites More sharing options...
February 26, 201312 yr Author comment_416279 Thanks guys! Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-416279 Share on other sites More sharing options...
May 4, 201311 yr comment_422513 just wondering.. ANYONE on the East Coast have a few R180 3.36 they want to sell ???I need a 3.36 for my SBC Powered 280Z with a turbo 350 trans and 225/50/16 tires to get it above 110 mph.. Thanks.. Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-422513 Share on other sites More sharing options...
May 5, 201311 yr comment_422524 Not an R200? I would wonder if an R180 would stand up to Chump Car abuse, especially with a 350.By the way, we met at The Mitty.Edit - You might be able to get one from Eddie Radatz. I'll bet he has some laying around. Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-422524 Share on other sites More sharing options...
May 5, 201311 yr comment_422569 Hey Steve.. Hey I would LOVE an R200 3.36.. Good luck finding one.. Yes Eddie and John BOTH have R180 3.36's But... Im not paying $300+ for one.. Remember its Chump.. The guy above crushed a bunch.. as far as power.. I have pushed 300+ through R160's in 510.. and I have an R180 3.54 in a 1977 280Z with 250hp.. No issues.. It all depends on how you drive them.. Rod Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-422569 Share on other sites More sharing options...
May 5, 201311 yr comment_422578 Almost thought I might have had one with the 71 240z I just picked up yesterday...but then I remembered it was in the process of being swapped to manual >_< Link to comment https://www.classiczcars.com/forums/topic/45834-whats-a-336-r180-worth-so-i-dont-get-scammed/#findComment-422578 Share on other sites More sharing options...
