someone's def already done that. last year i sifted through and found an xls with all of the info and pics for each fastener in the front and rear suspension. i also found other docs with the location of the fasteners labeled on a fsm picture.
i also remember searching ebay or somewhere and finding fastener sets. this was about a year ago so maybe not available anymore.
when i took the front suspension off my 260z they were still zinc plated and in good shape. but i do want to replace them all at one point. for piece of mind, if anything.
Yeah, I found a few "sets" on eBay for almost $300. All stainless steel bolts to replace everything on the car and some engine parts as well.
There must be thousands of fasteners from 1.5mm to 18mm. You probably should first place limits on the sizes, say from 3mm to 12mm, or to catalog only certain areas, like the engine-only, or suspension-only, so you can make the task a manageable one.
