March 1, 201312 yr comment_416578 Great info, thanks! My dad tells me this is what you do Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416578 Share on other sites More sharing options...
March 1, 201312 yr comment_416580 Used to sell diff parts, business failed. Didn't do a lot of installs, but I've done more than most people at about 10. Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416580 Share on other sites More sharing options...
March 1, 201312 yr comment_416581 A friend of mine who has only done one or two suggested a beam or dial type inch pound torque from a bike shop for only $30 or so in order to get the preload specs. Would you agree with that? Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416581 Share on other sites More sharing options...
March 1, 201312 yr comment_416582 The only dial type that I've ever seen in Snap-On and it's $250 last I checked. A cheapo beam works, and you want to spin it just fast enough that you overcome the stiction so the needle doesn't bounce around. Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416582 Share on other sites More sharing options...
March 1, 201312 yr comment_416593 Hi Jon: Weren't Ring & Pinion sets sold in matched set's, which you didn't get if you ordered the parts individually? I recall running into that problem at one time...FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416593 Share on other sites More sharing options...
March 1, 201312 yr comment_416595 R&Ps are matched sets. I've never heard of anyone selling a ring or pinion separately for that reason. Have seen the odd instance where a guy tries to change from a 3.70 to a 3.90 by installing a 39 tooth ring gear onto a 10 tooth pinion out of a 3.70 and that absolutely does not work. Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-416595 Share on other sites More sharing options...
April 8, 201312 yr comment_419869 hey, i was google searching r200 longnose ratio info and came across this thread, iv just acquired a 3.9 which is my ideal ratio and so now im selling my 4.37 ratio r200 longnose as either a CWP set or complete diff. i however am in christchurch, new zealand. but i do have a couple of very good friends that are in international shipping if your intrested in this diff/CWP set. add me on facebook if you would like to discuss this further via chat or phone.http://www.facebook.com/daniel.m.adams Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-419869 Share on other sites More sharing options...
April 9, 201312 yr Author comment_420038 Is your diff a LSD? Too bad, but I have a 3:90 open R-200 that we could have done some swapping. Let me know.... Link to comment https://www.classiczcars.com/forums/topic/45869-ring-and-pinion/?&page=2#findComment-420038 Share on other sites More sharing options...
