Rear Main Seal Part Number
fastd
Just replaced rear seal but looks like I still have a leak; I had to pull the tranny again for other reasons so will replace seal again. Didn't replace the side seals; will do those later. I didn't grease the main seal before I installed the first time; so since the tranny is out again, will do it right this time.
Called Nissan to ask for the seal but they have two different part numbers: 12279-2B500 and 12279-R4611. I have a 260z block - any opinions about the right part number?
Also, is Nissan geniune replacement seals the best seal to reinstall? Better luck with Felpro or others?
Thanks.
Thanks.
The part numbers you are quoting dont match the original E-Fast system. The E-Fast system is quoting 12279-21003, 12279-21010 and 12279-R4600. The number 12279-R4600 was changed to 12279-R4601.
  • Who's Online   0 Members, 0 Anonymous, 455 Guests (See full list)
