Year etc???
The passenger seat had a pressure switch mounted in the springs for the passenger seat to turn on the seat belt warning light if someone was sitting in the seat. It could be the wiring for that switch.
jlp
The speaker wire is buried in the bundle running along the right side rocker and disappearing into the dogleg. Check your parking-brake and find the button switch under the handle. There should be a single wire attached to it. The switch goes to ground when the parking-brake handle is lifted, this turns on the light on the dash. As a test, ground your mystery wire with the ingnition on and see if the brake light on the dash comes on.
A Z car owner was launched today into low earth orbit due to a wiring malfunction, news at 11.
Only wire in my 1970 model in that location is the emergency brake switch for the red warning light in the speedometer.
Edited by Mikes Z car
