March 11, 201312 yr comment_417520 djwarner, did you tweak the adjustment screw on the back of the clock to slow the clock down? Seems like that should resolve your problem. I have had great luck cleaning up old clock mechanisms with appropriate cleaning solution, lubricating the swivel points, making sure the motor works and off she goes. Link to comment https://www.classiczcars.com/forums/topic/45967-clock-redo/?&page=2#findComment-417520 Share on other sites More sharing options...
March 11, 201312 yr comment_417532 duffman said: djwarner, did you tweak the adjustment screw on the back of the clock to slow the clock down? To be honest I was so tickled pink that it was running reliably that I re-installed it and put the new glove box in. 5-10 minutes per day was perfectly acceptable for a car clock in the day. I'm not that anxious to pull the new glove box out and play for several days to get it any closer. Link to comment https://www.classiczcars.com/forums/topic/45967-clock-redo/?&page=2#findComment-417532 Share on other sites More sharing options...
March 12, 201312 yr comment_417554 djwarner said: 10 minutes per day I'm not sure if this is a typo or not, but you've said it twice now... You're happy with 5-10 minutes of clock error per DAY? To each his own, but I would not be happy with that. I'm thinking you meant per week, or month? Link to comment https://www.classiczcars.com/forums/topic/45967-clock-redo/?&page=2#findComment-417554 Share on other sites More sharing options...
March 12, 201312 yr comment_417556 Page 21 of the owner's manual states, "For best results reset the clock on a daily basis." Back in the day, as old man Harrison says on Pawn Stars, a quality wrist watch was only good for 1-2 minutes per day. I do have a clock display on my radio, so resetting is no big deal. Link to comment https://www.classiczcars.com/forums/topic/45967-clock-redo/?&page=2#findComment-417556 Share on other sites More sharing options...
