Gotta get rid of these parts, and as a mod pointed out to me earlier, I believe we can use this forum for last resort before the scrap yard, large collections, lot deals, etc. That said, I've got spare parts from my datsun and another donor 280zx I pulled parts from. I need them gone, and thus, will take reasonable and probably unreasonable offers. LOL If you guys don't, most are headed to the trash. Most of the parts off the 280zx I never tested. :( I could if you really want me to....
What I've got:
  • R180 diff. Dirty as can be and I believe it vibrated bad before parking. Needs rebuild. It's pulled. $40? $30?
  • Exhaust manifold off L28 F54 block. Painted white by PO but it's peeling now.
  • Transmission mount.
  • Exhaust with flange adapter. 2.5" exhaust will bolt directly up to a 260z. Just need the mounts welded on. It has an N1 generic muffler on it. Sounded really good with the silencer on, though. Breaks at the center for servicing rear of car.
  • Airbox off 280zx
  • 260z wiring harness. It worked when pulled, but there are a few things that have been mickey-moused on it by the PO. The gauges in the picture don't come with it.
  • 280zx washer fluid container. Untested, but holds fluid.
  • Misc trim pieces as pictures. Untested
  • Misc exterior trim
  • 280zx injectors. Some are hopefully still good or good candidates for cleaning
  • Headlight brackets (comes with FREE lights! Ha!)
  • Hazard/turn lights untested.
  • Gas cap, misc latches, dome light, tow point
  • Horns
https://www.classiczcars.com/forums/topic/45974-used-dastun-parts-sell-off/
I didn't see the wiring harness. Is it all of the wiring harness? Engine harness? Dash harness? Body harness?
Also are those S30 eschuteons? If so, I'm interested.
Snap... I didn't upload the wiring harness pic. I will do that later.
I have the engine harness. I could be persuaded to part with the dash harness at the right price. The dash harness is in better shape, but i would plan on redoing connectors here and there on both harnesses. The PO wasn't the best of electricians.... :-/
The door handle eschuteons are from a 79 280zx.
Diff cover, bolts, and bolts in diff nose are SOLD! I'll part out the rest of the diff if people want the stuff.
The gears look in great shape and there is almost no metal in the bottom. Yet the car shook really bad (increased with speed). Maybe it was transmission, driveshaft, or u-joint imbalance? Anyway, diff internals look good if people want the parts.
Bump!
I have two radiators, one in working condition, one that needs cored.
I also have a gas tank from the 260 in very good condition. I think the PO had it cleaned out because it is very clean inside. I went ahead and sanded down most of it, it just needs another 45 minutes of sanding and paint.
Also have the engine harness and dash harness.
The injectors ARE SOLD!
Still got the others parts, and the gas tank is in super good condition. I'll even finish sanding it for the right price.
The diff gears and other parts on the diff look good, too. Pinion gear, etc....
I don't have a picture, but I think I would like to just get rid of the dash and engine harness, too.
