March 19, 201312 yr comment_418368 OK, I managed to find my box of used carbs, and I selected a single 40DCOE-18 that might be a good candidate. The manufacturing date is a little later than yours ( mine is no.27752 ) so it's not really a perfect match. However, theoretically any early 40DCOE-18 should match up with another early 40DCOE-18 as far as circuits and internals etc, so it should work. I'm away in Japan for a couple of weeks from tomorrow, so can't really do anything about this until I come back. Hope you can wait.... Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-418368 Share on other sites More sharing options...
March 20, 201312 yr comment_418407 Koalia, you might try contacting Jeff Winter with Rallye-Sport in Westminster, CO. He is one of the best L-Series engine builders in the US and he might have a matching carb for you. Try emailing him at: rsport@qwestoffice.net or calling him at: 303-427-0510. If he does not have it he will know where to get it.Good luck!JTIII Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-418407 Share on other sites More sharing options...
March 20, 201312 yr Author comment_418415 Thanks Alan! Im in no rush, im planning to drive with SU's this summer, or at least the beginning of it, cause getting all the jets etc etc is money eating process. Got to take this slowly so i can afford to buy butter to cover my bread Might a trade come in question? I have no use for that 149 series Weber. Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-418415 Share on other sites More sharing options...
April 16, 201311 yr Author comment_420687 Back from your trip yet Alan? Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-420687 Share on other sites More sharing options...
April 16, 201311 yr comment_420692 Yes, I'm back. But very busy at the moment..... Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-420692 Share on other sites More sharing options...
April 17, 201311 yr Author comment_420845 No worries Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-420845 Share on other sites More sharing options...
May 15, 201311 yr Author comment_423468 Still looking for extra 18 series weber if anyone has one for sale (or giveaway ) Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-423468 Share on other sites More sharing options...
May 15, 201311 yr comment_423473 I've still got the one I offered to you.You don't want that one...? Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-423473 Share on other sites More sharing options...
May 16, 201311 yr Author comment_423520 Yessir i do! I just tought you had forgotten Got to keep me channels open. Should we continue this via PM or here? Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-423520 Share on other sites More sharing options...
December 19, 201311 yr Author comment_438178 Well i decieded to continue this old thread, as this kinda is about my good luck with carburators. I ordered a linkage set from pierce manifold, provided them pictures of my current setup and write up. First of all, the rod is way too long, i guess you can cut it shorter without ruining it. Secondly, rod ends are with wrong threading, does not fit the manifold. Thirdly, IF the rod would be cut to proper size, my linkage wouldnt work as the brake booster tube is on the way... Check the pics. What would you do? Im still learning, dont want to be spoon fed but some creative ideas would be nice.http://sdrv.ms/19zV7Ufhttp://sdrv.ms/19zV8HOhttp://sdrv.ms/1cChDJo Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-438178 Share on other sites More sharing options...
December 19, 201311 yr comment_438181 Analysis:1. It looks like the vacuum line tap in the runner uses the same casting locations as the rod-ends that hold the linkage-rod. Solution 1. Try to fit or make a low profile 90degree fitting for the hose so that it is diverted at the manifold and does not interfere with the linkageSolution 2. Try to find another casting location on the manifold for drilling and tapping a new vacuum line fitting2. Sadly, from experience, the guys at Pierce are nice but not the brightest. They should have asked you about metric fittings as you are in Europe. Being in the states, most of their product line is not metric thus the size / thread differences.Solution 1. You should be able to source the metric components in Finland (ss linkage-rod, rod ends). Call a machine shop or engine rebuilding shop and talk to someone there. Here in Canada, I can buy the stock for linkage rod in most hardware stores....not SS but they have it...in imperial sizes though.Solution 2. Assemble your manifold and carbs, no linkage. Bring this and the stock linkage from the Z (noting distances from where that last shepherd hook sits relative to runner 1) along with photos of linkages and manifolds to a machine shop along with your heap of linkage parts and ask them to finish the assembly and supply any require parts to make it work.Looks like you are on the home stretch now! One more push and you will have it sorted!btw What manufacturer of manifold do you have? Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-438181 Share on other sites More sharing options...
December 19, 201311 yr comment_438208 Some helpful photos here: http://www.classiczcars.com/forums/carburetors-s30/37492-lynx-manifold-photos.html#post446728 Link to comment https://www.classiczcars.com/forums/topic/46011-major-screw-up/?&page=2#findComment-438208 Share on other sites More sharing options...
