Losing Ground?
Zachary Lawson
My ECU seems to lose ground or connection when I drive for long periods of time. It pretty much stops working, and overloads the injectors. The only way to fix this problem is to push really hard on the connector on the ECU. I've taken it out and clean it a few times. Another problem I have that might be related too it is the tick hand, and the light above the heat controls. These work about 10 percent of the time. If I park on a slope, they work 99 percent of the time when I get in my car. Within 5 or 10 minutes later, they both stop working. When the tick hand is working, the car seems to run better. I'm losing ground on my wiring harness? Are these related?
Edited by Zachary Lawson
Another possible reason for your problem could be a cold solder joint somewhere inside the ECU, hence the issue being solved when you press really hard on the connector. You might open up the ECU and inspect the solder joints very carefully under a magnifying glass. You would likely be looking for a cold (fractured or separated) solder joint in the area of the electrical connector. Another approach would be to break out a soldering iron and to re-flow the multitude of solder connections (re-melt the solder at each connection).
In this case I would get the Fuel Injection Book and do all the tests the book mentions dealing with all kind of problems done at the _ECU harness connector side_. Hopefully, your multimeter will give you a clue which circuit is loose or disconnected. This will take you an hour.
For example, while running the temp sensor tests, your multimeter shows 15kOhm reading when the book shows 0.5kOhm. You now go directly to your temp sensor engine connectors and repeat the test. It shows the correct reading. Now you identified the electrical wire pair which causes this abnormal reading.
Regards!
Well, your resolving the issue through connector shoving is a major clue. Wherever you're shoving, you have a bad connection or a short. If I were you, I'd open up the connector shell to examine the wire connections inside. And then unwrap that segment of the wiring harness to look for shorts or other weirdnesses. Obviously also look for bad grounds. However, I think the ECU is grounded through the case (maybe I'm wrong??), and you've already done an R&R of the ECU.
That is not the case. (Get it? Not the case?) LOL Nevermind.
They are NOT grounded through the case*. In fact, they were very careful with their grounding scheme, and while the case is in fact grounded (by virtue of being bolted to the body), there is no electrical connection between the case and anything inside. All of the grounding of the ECU electronics inside is done through the EFI harness wire connections.
*I've not messed with years prior to 77, but I assume they're all the same in that regard.
Regards!
Yeah I'll check into that.
Well, that's interesting because the tachometer and the ECU both get their signal from the negative post of the coil. So, in addition to whatever is going on with your connector, you should check connections at the coil and ballast resistor. You might have a loose connection there.
It could also be that your ignition module is going bad. That will cause your tachometer needle to jump around too.
Edited by Zed Head
  • Who's Online   0 Members, 0 Anonymous, 434 Guests (See full list)
