Electrical Connectors
Classic83owner
Can any one tell me if fuel injectors, coolant temp sensor, etc. use the same connector. They all look the same but I haven't tried one on the other or checked part numbers on the replacements. I found I can buy new ones from O'Reilly Auto Parts for $6.99 and its' so much easier to solder in new ones than it is to pick and clean the old ones.
On my '77 they are the same. You get a good deal off ebay with connectors and heat shrink to cover the solder. He has kits of 6 and 10, don't forget the cold start valve.
http://www.ebay.com/itm/injector-connector-kit-6pc-datsun-280z-280zx-300zx/290452375892?ssPageName=WDVW&rd=1&ih=019&category=33553&cmd=ViewItem
Edited by siteunseen
I contacted
Vines Auto
Mobile: 1-800-214-4839
2460 Morgan Road S.E.
Bessemer, AL. 35022
Office phone: 205-426-2697
Office fax: Fax 205-426-2699
where they dismantle BMWs, and was able to get an entire engine harness that provides enough connectors for several engines. I even got some rubber parts that worked for the headlamp harnesses ( the rubber covers that go from the inner fender to the lamp.)
I think I paid about $25 plus p&p.
I need some other connectors, like a couple bullet types for things, but those are found easily.
  • Who's Online   1 Member, 1 Anonymous, 630 Guests (See full list)
