Louver hardware
crazee1
Does anybody have the lower spring loaded barrell bolts for a rear window louver? I just bought a 70 240 Z and it has holes drilled in the deck that are 1 1/4 inch apart. I can refurbish the louver, but cannot find this hardware anywhere.
Any help is appreciated.
Direct e-mail to stevepharr at cox dot net would be best.
Here is a picture for you. There is right and left side.
[ATTACH=CONFIG]61964[/ATTACH]
Thanks
I made some aluminum brackets to use the existing holes. Cleaning the window will now require removing 2 bolts but this car will not be seeing that much use to worry about it.
craZee
