Hey everyone, I just finished up my 240Z with new suspension and a fresh tuning, and I'm waiting for the snow to melt so I can get it aligned. I have the factory specs on alignment, but there's not much left on this car that's stock. It's a 3.1 Stroker engine with all the trimmings you might expect.
I'll be using it as a daily driver, albiet a sporty one, and I've installed camber bushings for some adjust-ability. I've also got the upgraded compression arms in the front, so I should be able to adjust caster somewhat as well.
So, my question is, are there recommendations other than stock for these types cars?
Thanks Blue, I did a search for recommendations earlier and did find that thread. There wasn't anything else, though, so I wanted to check. I'll use those if I can find an alignment shop willing to do to the work!
