1970 240Z For Sale
Note: This car has been dented from hit and run drivers (that's the streets of San Francisco for you) there are cracks in the dashboard, and the drive shaft is bent, otherwise its a phenominal car (see the stats below)
1970 Datsun 240Z
2.9 liter L28 with early E31 head.
Recently and professionally installed 5-speed transmission
High compression pistons
Bigger valves
Cylinder head race porting by Lafayette Motorsports and Morgan Machine and Marine.
Triple 44mm Mikuni sidedraft carbs
High-lift cam
High-flow turbo oil pump
6 into 1 header
Custom flowmaster exhaust
New MSD ignition
Very New Fuel Pump and filter
Very New Cap, Rotor, wires, plugs, and contacts
Very New Oil Pump
Very New Rear Brakes
New differential
Suspension Techniques sway bars, Front and Rear
Lowering springs
All urethane bushings
KYB race struts
15x7 Eagle Alloy rims w/ 225/50/15 Venus tires
H-4 high output headlight conversion w/ European headlight lens
All original interior (in MINT condition)
Sony CD Player w/ 100w Amp and boxed 6x9 Pioneer Speakers
Vibrant red color exterior
Have ALL receipts!
No smog test needed...Smog exempt!
All major work done professionally by Rebela Racing , Dando, and Lafayette Motorsport
$5000 or best offer (NADA.com blue book value 5k- 14k)
Phil
(415)-572-7837
phil@sfnitelife.com
see the pictures here
http://sfnitelife.123hostnow.com/sfnitelife/origImageTree/zcar/index.html
https://www.classiczcars.com/forums/topic/4614-1970-240z-for-sale/
