April 9, 201312 yr comment_419968 ah, then it's been replaced with an aftermarket grose jet at some point. Some people swear that they're better, some people swear they'll stick up and burn your car down. I don't have any anecdotal or scientific info either way, my car has stock valves and they work fine. Probably wouldn't be a bad idea to replace 'em if you're having problems (either with stock style valves or new grose jets, new is new. I'll wait for one of the old-timers who knows more than me to chime in though) Stock ones look like this: Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-419968 Share on other sites More sharing options...
April 9, 201312 yr Author comment_420048 Ah man, well least I now know. Hopefully cleaning them out has helped till I can order thos you posted in the picture. I cleaned them and poured sea foam on them, in the jets, and lines. Ill probably go to auto zone and get new floats as well while im at it. Going to check out newdatsunparts.com right now. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420048 Share on other sites More sharing options...
April 10, 201312 yr comment_420088 seafoam won't help. Clean with air pressure pistol. You might have deposits in the carb from sitting still for so long. That's a problem in the place where the needle goes into the seat, it will not close properly and leak. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420088 Share on other sites More sharing options...
April 10, 201312 yr comment_420102 Ah man, well least I now know. Hopefully cleaning them out has helped till I can order thos you posted in the picture. I cleaned them and poured sea foam on them, in the jets, and lines. Ill probably go to auto zone and get new floats as well while im at it. Going to check out newdatsunparts.com right now. When you are at Auto Zone buying floats, buy us some. as many as they'll sell you. There are no new floats, at least that we have been able to source. This would be one of those instances where that one guy sitting on a stash of floats could be everybody's buddy.... Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420102 Share on other sites More sharing options...
April 13, 201312 yr Author comment_420388 Ya autozone doesn't carry them anymorw. Yet they show a picture of the ones I need. Ill see if I can contact gpsorsen. Doubt ill have any luck there. I think I've got them all cleaned up now and will try to put them on tommarow and see what happens. I need to make a build thread on this car haha. Just got the msd tach adapter today too. Again thanks for all your support and advidce and help on this topic guys. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420388 Share on other sites More sharing options...
April 13, 201312 yr comment_420393 I was just dismantling my 72 SU carbs today and notice your float bowl cover isn't "under" the carb body edge as is mine. I had to remove the float assembly by removing the parts above the cover to get it out.... Anyone know why the difference? Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420393 Share on other sites More sharing options...
April 13, 201312 yr comment_420441 Ya autozone doesn't carry them anymorw. Yet they show a picture of the ones I need. Ill see if I can contact gpsorsen. Doubt ill have any luck there. I think I've got them all cleaned up now and will try to put them on tommarow and see what happens. I need to make a build thread on this car haha. Just got the msd tach adapter today too. Again thanks for all your support and advidce and help on this topic guys.I spent some futile hours awhile back looking for floats to no avail. Several outfits shpwed 'em, no one had 'em. One in particular showed they had BOTH carbs for sale AND the floats as the third and final item. Thinking this looked pretty promising I called them only to be met with "we don't carry carburetor items" ..... Well hell Finley then why is your Zcar listing so definitive? Both carbs and floats sure sounds like you might handle carb stuff!!Twooley amazing how many company websites don't seem to have a periodic cleanup function..... Ours comes to mind..... That Grose Jet section needs to go away but we don't seem to be ablre to Git'er dun!!Here ends the rant..... Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420441 Share on other sites More sharing options...
April 13, 201312 yr comment_420458 [ATTACH=CONFIG]62561[/ATTACH]I was just dismantling my 72 SU carbs today and notice your float bowl cover isn't "under" the carb body edge as is mine. I had to remove the float assembly by removing the parts above the cover to get it out.... Anyone know why the difference? Helps to spin the lid 90 degrees to remove/replace it. Also, if there's fuel in the bowl it helps to drain it. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420458 Share on other sites More sharing options...
April 14, 201312 yr comment_420503 Thanks - I tried that several times but the inner pieces got caught up. I was able to get it all apart be disassembling all of it then removing the pieces, but not sure if I can get it together in the same way.Still have my original question - why the difference? They are from a 72 like the OP's, but different. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420503 Share on other sites More sharing options...
April 14, 201312 yr comment_420513 What do you mean e-tek? The float bowl is locked to the main housing with only 1 nut ( at least that was the case with mine ), it's easier to take it off. @3ryce: an easy way to check if the float is closing in time, is to put a little hose on the top gasoline feed, and put into your mouth. For testing clean first, and leave the float valve connected to the top of the housing. Then when the hose is in your mouth, blow pressure on it, and move the float bowl gently up, to notice where it's closing, if it works you should not be able to blow anymore air through the hose. The float bowl should not be all horizontal when closed, a little under it. Edited April 14, 201312 yr by bartsscooterservice Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420513 Share on other sites More sharing options...
April 15, 201312 yr Author comment_420564 I'm not sure I see the differance you are talking about etek. I still have to turn mine to get the top off. Oh but about the overflowing problem! Got it fixed and it seems to work fine now. I had to do some adjusting as it was idling to high so I adjusted the adjusting screws. Next is to get that tester you put in from of them to make sure both are pulling the same amount of air. Ill noticed my secondary coil on top of my ignition coil was super super hot. I don't think its supposed to be that hot so I gotta look into that next. I need to make a build thread haha. Link to comment https://www.classiczcars.com/forums/topic/46186-help-me-identify-these-carbs-please/?&page=2#findComment-420564 Share on other sites More sharing options...
