Removing the Emmissions stickers
TomoHawk
I stripped all the undercoating from the underside of the bonnet, and found the two stickers. They don't seem to want to come off, so maybe someone has some tips to persuade a 40 year-old foil sticker to come off? Solvents aren't having any effect, and a metal blade will probably scratch what's underneath.
the new razor blade was able to get under the sticker so I could pull it off. Be careful not to dig into the paint, and watch out for those sharp corners.
One sticker came off in strips, and the other in one piece. Only the adhesive residue is left, and brake cleaner didn't do much to it, so I will have to try something stronger.
