240z shift map
ElCimino
What year is your car? The 71 240Z I had back in the late 70s had a black and white 4 speed map. I THINK the green map was for a later 240Z model.
1973 I'm not super worried about keeping it factory original but if you know the correct color for the year ill try to find that. Finding the map is proving more difficult than I thought.
The maps are very hard to find. I have a 76 and the map is green. I found one on ebay a couple weeks ago. Mine was made of metal.
Your is plastic I am pretty sure. Here are some pictures I saves from another thread.
The green one is for 75, 76 and maybe 4 speed 77. The black with white letters should be for 73. The diameter of the green is 1 1/16 inches.
So would the green one fit a 73? I don't want to spend $25 on a map that won't fit.
