Posted April 16, 201312 yr comment_420763 I would just like someone to confirm that Toe in is the only adjustment I can make on an early stock 240Z.Just putting the whole car back together.Thanks,Chris Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/ Share on other sites More sharing options...
April 16, 201312 yr comment_420767 Confirmed. The only wheel alignment adjustment provided is front wheel toe. Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/#findComment-420767 Share on other sites More sharing options...
April 17, 201312 yr comment_420809 Hi Chris,Just for reference purposes here are some alignment specs as per Carl Beck:Front:Toe: 1/16" to 3/32"Camber: 0 to 1 negative with 1 being preferred.Caster: 4 to 6 positive The actual number between 4 and 6 is not important, only that both sides are the same.Rear:Toe: 1/16"Camber: 0 to 1 negative with 1 being preferred.Track: Make sure the rear wheels track the front.Note:Toe is in inchesCamber and Caster are in degrees.Hope this is of value to you.Cheers,George Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/#findComment-420809 Share on other sites More sharing options...
April 17, 201312 yr comment_420817 I just adjusted my toe-in this past weekend via the 'string' method. I ended up using the 2mm-5mm toe-in setting. Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/#findComment-420817 Share on other sites More sharing options...
April 18, 201312 yr comment_420871 I run 1/8" toe out in the front for crisper turn-in. Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/#findComment-420871 Share on other sites More sharing options...
October 27, 201311 yr comment_434607 Want to be sure this set of specs for aliment is the same for a 78/280z. Thanks JB Link to comment https://www.classiczcars.com/forums/topic/46288-toe-in/#findComment-434607 Share on other sites More sharing options...
