Posted April 18, 201311 yr comment_420950 Hello,I'm struggling at tracing one white on green wire and one melted black wire, in the FSM & posted wire diagrams, that have been broken. They are dangling under the dash. I attached a picture. Can you take a look and offer any suggestions?ThanksRobertWires Under Dash.pdf Link to comment https://www.classiczcars.com/forums/topic/46311-2-cut-wires-dangling-under-dash-1975-280z/ Share on other sites More sharing options...
April 18, 201311 yr comment_420952 The green/white wire is usually associated with the parking light circuit. I can't really tell where under the dash you took the picture. However, from seeing the bullet connector, I would think it might be glove box lamp. Link to comment https://www.classiczcars.com/forums/topic/46311-2-cut-wires-dangling-under-dash-1975-280z/#findComment-420952 Share on other sites More sharing options...
