240z fuel and brake line insulator sets and steering rack expansion reservoir
nix240z
Another item, this time it is the 240z quarter window upper rubber seals.
The right and left set is $16 plus shipping inside the usa.
Replace your old or missing seals.
seal on the upper quarter window.
right and left seals
Clarification on this part.
The original part numbers are:
76837-E4100 & 76838-E4100 WEATHERSTRIP-SIDE WI this type was longer, which was replaced with 76837-N3400 & 76838-N3400 WEATHERSTRIP-SIDE WI ( Shorter type, this is what I reproduced)
Then replaced with 76837-N4500 & 76838-N4500 WEATHERSTRIP-SIDE WI This is the newer type from nissan which covers the entire quarter window, with the screws.
This is the shorter type that also comes with a 1/4" filler piece that is glued in place, just like from the factory.
PM me if you have any questions.
Steve
[ATTACH=CONFIG]65212[/ATTACH]
[ATTACH=CONFIG]65211[/ATTACH]
76837-E4100 & 76838-E4100 WEATHERSTRIP-SIDE WI this type is longer, is now also available.
Same price, $16 plus shipping for a set of the right and left.
short type (76837-N3400 & 76838-N3400 WEATHERSTRIP-SIDE WI) and the longer type (76837-E4100 & 76838-E4100 WEATHERSTRIP-SIDE WI).
shorter version on bottom and longer version on top.
rubber on the upper quarter window.
More rubber parts are in the works..
It may be a good idea to make a variant of that bumper so that it stops the window higher. The top of the glass should just stop with the top edge of the squeegee so that it is held firmly at the top by Mr. fuzzy, Mr. squeegee and Mr. roller. This prevents rattling of the glass if it were wound down further.
Edited by Blue
  • Who's Online   0 Members, 0 Anonymous, 768 Guests (See full list)
