September 28, 201410 yr Author comment_456169 I have been working on a few new items, one is the rubber seal for the antenna to rear quarter panel. The second item, which is still in the development stage, is the voltage regulator 6 prong connector protective boot, this one is gone 99% of the time. Picture of new boot coming later this week. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456169 Share on other sites More sharing options...
September 29, 201410 yr comment_456267 I'm working on a large list for you. A lot of these parts transfer over to the 280. How is your car coming along? Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456267 Share on other sites More sharing options...
September 30, 201410 yr comment_456319 Handbrake handle and pushbutton. These were never available separately and since NOS handbrakes are NLA we are forced to restore the originals. Unfortunately, these parts are destroyed during their removal. Early 240Z wiper motor cover. Before there was the “bag†Nissan used a plastic cover. Speedometer cable and hood opener cable grommet. The very early 240Z’s lacked a separate hole in the firewall for the hood opener cable, so Nissan combined it with the speedo cable. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456319 Share on other sites More sharing options...
October 3, 201410 yr Author comment_456542 Handbrake handle and pushbutton. These were never available separately and since NOS handbrakes are NLA we are forced to restore the originals. Unfortunately, these parts are destroyed during their removal. Early 240Z wiper motor cover. Before there was the “bag” Nissan used a plastic cover.Speedometer cable and hood opener cable grommet. The very early 240Z’s lacked a separate hole in the firewall for the hood opener cable, so Nissan combined it with the speedo cable.I have looked at the handbrake and it seems that the rubber is a different type than the urethane I use. I could do the Speedometer cable and hood opener cable grommet, I would just need a sample for correct measurements. I would also need a good sample of the Early 240Z wiper motor cover.Steve Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456542 Share on other sites More sharing options...
October 3, 201410 yr Author comment_456543 I'm working on a large list for you. A lot of these parts transfer over to the 280. How is your car coming along? Ok let me know when ready to order. Not much work on the car over the summer, making and selling parts takes up all my extra time. I have had over 16000 hits on the website and have filled over 100+ orders all over the world, thanks to all who have ordered parts from me. Steve Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456543 Share on other sites More sharing options...
October 5, 201410 yr comment_456621 Thats awesome! Thank you for everything you're doing. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456621 Share on other sites More sharing options...
October 5, 201410 yr Author comment_456630 preview of the voltage regulator 6 prong plug protective boot. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456630 Share on other sites More sharing options...
October 5, 201410 yr Author comment_456655 I am also working on the 240z rear interior strut cap, I should have a sample this week. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-456655 Share on other sites More sharing options...
December 7, 201410 yr Author comment_460029 Finished the rear strut cap. Exactly the same as Nissan. I'm also working on a few other items. The headlight wire plug socket boot. also the plastic pins that hold the fiberboard kick panels on the left and right side. Steve Nice tight fit. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-460029 Share on other sites More sharing options...
December 10, 201410 yr comment_460115 Damn I just ordered a set of these off ebay Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-460115 Share on other sites More sharing options...
December 12, 201410 yr Author comment_460264 Few things in the works. Plus I have some other items in the works. Headlight wire end boot. 95% of these I have seen are rock hard and deformed. any interest in these? 240z turn signal mounting hardware. I needed a set since mine were rusted out. I machined the bolt down on my lathe. cut and bent mounting plate drilled hole tinned metal for soldering soldered bolt to mounting plate and then they will be zinc plated. Steve Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-460264 Share on other sites More sharing options...
December 13, 201410 yr comment_460275 a spot welder may fuse the bolt to the plate too. Link to comment https://www.classiczcars.com/forums/topic/46317-240z-fuel-and-brake-line-insulator-sets-and-steering-rack-expansion-reservoir/?&page=12#findComment-460275 Share on other sites More sharing options...
