  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
few more small misc items I have been working on.
might not be a big demand for these but I needed them for my restoration so I am making these small items available.
Plus I am working on the lower Quarter window seals and these should be done soon.
u-bolt clamp rubber for steering rack
post-23426-0-92578900-1449343502_thumb.j
brake master cylinder bleed screw caps
post-23426-0-02007400-1449343793_thumb.j
Correct battery frame fire wall rubber insulator. There is a variation of this out there which is slightly different. If you want factory correct part then this is it.
The part number is 24480-e4600 NLA
post-23426-0-82628600-1450985892_thumb.j
Steve
  • 2 years later...
It has been awhile since I added a new item, since I just about have every part made. I now have the 70-71 rear brake cylinder rubber kit completed. You will need to reuse your retaining clip.
