Problem:
I checked continuity between terminals 6 and 27 at the ECU - it failed
Diagnosing Attempts:
1) I checked the continuity between terminal 6 and 27 on the Air Flow meter - it passes (sensor is good)
2) I jumped terminal 6 and 27 on the harness connector and checked the continuity - it passes (harness from ECU to Air Flow meter is good)
Therefore it must be the corrosion between the harness and the AFM.
3) I replaced the connector on the harness with a brand new connector and all new terminals. I cleaned the male terminals on the AFM and lubed them up with dielectric grease. And it FAILED continuity between terminals 6 and 27 when measured at the ECU.
What is going on? Any ideas?
Thank you,
Robert
