4 hours ago, TomoHawk said:
A fire extinguisher is the only tool or item I own that has just one purpose.
 Unless one owns a multi task CO2 extinguisher that will also chill beer.
I bought a 2.5lb Kidde unit and mounted it behind the passenger seat by using a 5"x10" piece of 5mm thick black ABS plastic with 4 riv nuts placed to coincide with the fire extinguisher's bracket holes. I placed the ABS base under the carpet and secured it to the floor with 3M heavy duty double stick tape, replaced the carpet and put 4 bolts through the base and carpet into the riv nuts. Finally I placed the extinguisher into it's very secure base.
  • 1 month later...
To mount my fire extinguisher I bought something called the Bracketeer.
http://www.thebracketeer.com/
I mounted it in front of the passenger seat.  It bolts to the factory seat mount bolts.  The clearance is nice.  It does not hinder the movement of the seat.
  • 10 months later...
