Posted April 25, 201312 yr comment_421552 I had some Eibachs installed today and after I got it back, I noticed that one of the rear springs was installed upside down. The lettering is upside down, luckily the rears were installed in the right place. I wanted to see if I should make a big deal about it. Is there any difference. Figured if it fit, it will probably be same either way. From what I can see, the top part, the notch lines up with the end of the spring. Edited April 25, 201312 yr by nismospek Link to comment https://www.classiczcars.com/forums/topic/46366-spring-question/ Share on other sites More sharing options...
April 25, 201312 yr comment_421590 The suspension doesn't care what the spring orientation is. Link to comment https://www.classiczcars.com/forums/topic/46366-spring-question/#findComment-421590 Share on other sites More sharing options...
April 27, 201312 yr Author comment_421696 Thanks for the info. Well that completes my suspension mods, now on to wiring. Link to comment https://www.classiczcars.com/forums/topic/46366-spring-question/#findComment-421696 Share on other sites More sharing options...
