Posted April 28, 201311 yr comment_421806 I have a set of 15" rims with new 205/65/15 tires . I have a set of tokico hps . I want to install the blues with the EIbach springs from MSA on a 70' 240z .... Will I have enough clearance ? any experience with this set up thanks Dan Link to comment https://www.classiczcars.com/forums/topic/46391-suspension-and-tire-size-question/ Share on other sites More sharing options...
April 28, 201311 yr comment_421839 There is enough room for the 205/65-15 as long as the wheel offset is very close to 0. We have used up to 225/50-15 without clearance issues. Link to comment https://www.classiczcars.com/forums/topic/46391-suspension-and-tire-size-question/#findComment-421839 Share on other sites More sharing options...
April 28, 201311 yr Author comment_421846 i think they are they are Kong rewinds I was more worried about the highth of the tire thanks Link to comment https://www.classiczcars.com/forums/topic/46391-suspension-and-tire-size-question/#findComment-421846 Share on other sites More sharing options...
April 29, 201311 yr comment_421900 205/60/15's rubbed with my panasports on Tokiko HPS springs and struts on stock body work. If you have a front valance that is not OEM, you may be okay. But with the OEM body work on that tokiko combo, the widest I can run is 205/55/15THe diameter gets too big on my car to run a 60 much less a 65 series tire. Link to comment https://www.classiczcars.com/forums/topic/46391-suspension-and-tire-size-question/#findComment-421900 Share on other sites More sharing options...
