suspension and tire size question
malibud
I have a set of 15" rims with new 205/65/15 tires . I have a set of tokico hps . I want to install the blues with the EIbach springs from MSA on a 70' 240z .... Will I have enough clearance ?
any experience with this set up
thanks
Dan
205/60/15's rubbed with my panasports on Tokiko HPS springs and struts on stock body work. If you have a front valance that is not OEM, you may be okay. But with the OEM body work on that tokiko combo, the widest I can run is 205/55/15
THe diameter gets too big on my car to run a 60 much less a 65 series tire.
  • Who's Online   2 Members, 0 Anonymous, 634 Guests (See full list)
