April 30, 201311 yr Author comment_422055 Yeah, I also downloaded the FSM a while ago. And I actually do have a 300ZX, 1990 2+2. Why? Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422055 Share on other sites More sharing options...
April 30, 201311 yr comment_422083 This forum is for earlier z cars. I think you would get more information at zcar.com. They have a dedicated 300zx forum.I think your cars year of manufacturing is later than 1978. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422083 Share on other sites More sharing options...
May 1, 201311 yr Author comment_422107 I thought you were referring to something I can take off of it. I have a 1978 280Z, and I have my old 1990 300ZX still also. I got in an accident in the 300ZX a while ago, and I still haven't decided exactly what I want to do with it yet.What I was saying is that the fuel injection book was updated in November 1975, an my car is a 78. It's fairly close, but there's enough of a difference that I'm not comfortable with relying on the guide. The FSM is a little bit better though. I have to trace down each and every wire to see what it is as well. Edited May 1, 201311 yr by pureZero Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422107 Share on other sites More sharing options...
May 1, 201311 yr Author comment_422118 I do have the injectors, and everything to install them, as well as a gasket kit. I also seem to have all the fuel lines except for most of the hoses. Anyone feel like taking a crack at telling me what all I'm missing? Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422118 Share on other sites More sharing options...
May 1, 201311 yr comment_422119 Here's a start. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422119 Share on other sites More sharing options...
May 1, 201311 yr Author comment_422121 Here's a start.That does help a little, thanks! Do you have a slightly more complete version of that though? I have the actual 78 wiring diagram printed out, which will help me greatly in tracing down the wiring. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422121 Share on other sites More sharing options...
May 1, 201311 yr comment_422127 You can lead a guy to the FSM, but you can't make him open it. Har har hardy har. It's a bread crumb.It's from the Engine Fuel chapter of the 1978 Factory Service Manual (FSM). That thing that we keep mentioning. From XenonsS30. It has smaller, specific wiring diagrams in it also, easier to work with than the the big one, although the big one is worth having also.Not kidding! It will help you out. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422127 Share on other sites More sharing options...
May 1, 201311 yr Author comment_422128 Just because I haven't looked through the FSM in over a week, that doesn't mean you can make fun of me for it haha But yeah, I know it'll help me out. I just don't have enough time to do much of anything on the car on weekdays. There's a lot of things that I have to do on the car still, so my mind is going off in 10 other directions right now. Between cutting out the rust on the floor pans and patching them up (temporary, until I can afford to get new floor pans for it), repairing the few other spots of cancerous rust, getting it running, and getting it safe to drive (ie. new bushing kit and brake/clutch lines), and college, I have a lot on my plate. The car's main saving grace is the fact that the inner fenders are completely solid, as are the strut towers. There's nothing that can't be fixed by someone with very little formal wire-feed welder experience, given that said person is extremely quick on the learning curve. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422128 Share on other sites More sharing options...
May 1, 201311 yr comment_422146 If you can, print out the section you need to refer to, and bind it. I also have a cheep notebook that I use to draw out the diagrams, wiring, etc. so they make sense and make it easier to refer to when you work. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422146 Share on other sites More sharing options...
May 2, 201311 yr Author comment_422244 A actually made a three-fold of the wiring diagram a while back. Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422244 Share on other sites More sharing options...
May 2, 201311 yr comment_422248 What I mean is that I put the wiring diagram on the kitchen table, and start following and drawing the circuit (eg. brake lamps, turn signals,radio, thermotime/cold-start injector) I'm interested in into the notebook, with wire colors and any other notes, so I don't have to stop work to go back to the wiring diagram. It saves a lot of time. If I need to look up a circuit later, I already have it drawn in the notebook (Indexed of course.) Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422248 Share on other sites More sharing options...
May 9, 201311 yr Author comment_422925 [ATTACH=CONFIG]63068[/ATTACH][ATTACH=CONFIG]63069[/ATTACH][ATTACH=CONFIG]63070[/ATTACH][ATTACH=CONFIG]63071[/ATTACH][ATTACH=CONFIG]63072[/ATTACH]Can anyone tell me why there seems to be third coolant port on the bottom of the block, below the thermostat housing? Link to comment https://www.classiczcars.com/forums/topic/46395-what-is-needed-for-a-1978-pfi-280z-to-run/?&page=2#findComment-422925 Share on other sites More sharing options...
