Posted February 10, 200322 yr comment_26271 Howdy. You may remember my car has been parked for 12 years or so. Should I drain the diff or just top it off? Any recommendations for oil to use? Link to comment https://www.classiczcars.com/forums/topic/4643-differential/ Share on other sites More sharing options...
February 10, 200322 yr comment_26273 Doesn't cost much to drain it and refill.90wt Gear Oil ---brand of your choice Link to comment https://www.classiczcars.com/forums/topic/4643-differential/#findComment-26273 Share on other sites More sharing options...
March 5, 200322 yr comment_28699 why wouldent you change it ? Think about it , was the oil fresh 12yrs ago ? Most likely not . Can water vapor condence in the unit over the years of sitting ? Most likely yes. Everyone knows that can do damage , why not spend a little time change it. Link to comment https://www.classiczcars.com/forums/topic/4643-differential/#findComment-28699 Share on other sites More sharing options...
