May 25, 20205 yr comment_600195 Many thanks to all for the wealth of useful information here! I am in the process of replacing the nylon line in a '77 antenna and was making good headway until I tried to separate the mast tube from the main housing. The two screws finally gave up their hold under heat but the tube isn't popping out as easily as I had hoped. Before I go at it again, I thought I should double check that the mast tube on the later models does in fact slip in to the housing (which appears to be the cast) and isn't threaded at the base. Any handy insight would be appreciated. Edited May 25, 20205 yr by chaskill Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-600195 Share on other sites More sharing options...
May 26, 20205 yr comment_600205 I had one that was so corroded that I simply could not get the mast out of the lower housing. I finally resorted to the brute force and ignorance method. Now that I've done that once and know what I'm dealing with, I might be able to come up with something a little less destructive next time (if there ever is a next time). But since I had no idea what I was doing, I cut it off and mangled the shite out of it until it came out. : Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-600205 Share on other sites More sharing options...
May 26, 20205 yr comment_600208 Ouch! I'm sorry for your loss, Captain Obvious. Thanks for the helpful pics though. That's what I was suspecting I might be up against, but glad I checked. I may try a drop of vinegar if another round of heating doesn't work. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-600208 Share on other sites More sharing options...
May 26, 20205 yr comment_600214 Use good penitrating oil not WD-40. I would avoid heat the cord or the guides might melt Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-600214 Share on other sites More sharing options...
May 26, 20205 yr comment_600216 11 hours ago, chaskill said: Ouch! I'm sorry for your loss, Captain Obvious. Thanks for the helpful pics though. That's what I was suspecting I might be up against, but glad I checked. I may try a drop of vinegar if another round of heating doesn't work. Well it wasn't a total loss, but it was one of those project steps which should have taken fifteen seconds turned into an hour of work. After the BFI removal, I cleaned everything up and made an "adapto-matic" extension to replace the original cut off portion and put the length back to where it should be. My aluminum adapter: Goop it up inside with silicone and put it back together:\ I actually made two adapters, but I don't remember exactly why. Either I needed to change diameters to use the mast from a different antenna, or it was simply "I cut it twice and it's still too short". Been too long to remember that detail, but in the end, the mast looked like this and it worked great: So like so many projects, it wasn't a total loss, but it took way longer than it should have because of unforeseen surprises. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-600216 Share on other sites More sharing options...
July 4, 20205 yr comment_602106 I managed to get the mast out using this penetrating liquid. But I cannot extend all parts of the mast. I can extend a few but not all.. I tried putting more liquid wrench into the mast itself and left it a few days but still didn't work. I also couldn't remove the mast tube from the body either.. I've tried a propane torch to heat it and penetrating fluid but so far no joy... any other ideas? I also got thinking about potential mast replacements.. for the arrow tip... A few are on eBay for $16. https://www.ebay.com/itm/Power-Antenna-AM-FM-Radio-Replacement-Mast-Cable-Cord-For-95-98-Nissan-240SX/323185742673?epid=20017502835&hash=item4b3f5f1351:g:JTkAAOSwnklawuIx This 1 looks close... https://www.ebay.com/itm/BRAND-NEW-POWER-ANTENNA-ROD-MAST-FOR-NISSAN-240SX-300ZX-MAXIMA-STANZA-1989-1996/223859901620?hash=item341f1704b4:g:IQYAAOSwydpeIpFN https://www.ebay.com/itm/Power-Antenna-Aerial-AM-FM-Radio-Replacement-Mast-Cord-92-03-Mitsubishi-Diamante/133089766376?hash=item1efcc4abe8:g:7~EAAOSwiuFepPQC If these are made of stainless could you dremmel them into an arrow tip shape? As a potential replacement? I'm thinking if this is made of stainless you could shave it down (to required profile) and then polish it up again ? Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602106 Share on other sites More sharing options...
July 4, 20205 yr comment_602111 1 hour ago, Gav240z said: I managed to get the mast out using this penetrating liquid. But I cannot extend all parts of the mast. I can extend a few but not all.. I tried putting more liquid wrench into the mast itself and left it a few days but still didn't work. I also couldn't remove the mast tube from the body either.. I've tried a propane torch to heat it and penetrating fluid but so far no joy... any other ideas? I also got thinking about potential mast replacements.. for the arrow tip... A few are on eBay for $16. https://www.ebay.com/itm/Power-Antenna-AM-FM-Radio-Replacement-Mast-Cable-Cord-For-95-98-Nissan-240SX/323185742673?epid=20017502835&hash=item4b3f5f1351:g:JTkAAOSwnklawuIx This 1 looks close... https://www.ebay.com/itm/BRAND-NEW-POWER-ANTENNA-ROD-MAST-FOR-NISSAN-240SX-300ZX-MAXIMA-STANZA-1989-1996/223859901620?hash=item341f1704b4:g:IQYAAOSwydpeIpFN https://www.ebay.com/itm/Power-Antenna-Aerial-AM-FM-Radio-Replacement-Mast-Cord-92-03-Mitsubishi-Diamante/133089766376?hash=item1efcc4abe8:g:7~EAAOSwiuFepPQC If these are made of stainless could you dremmel them into an arrow tip shape? As a potential replacement? I'm thinking if this is made of stainless you could shave it down (to required profile) and then polish it up again ? @Captain Obvious Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602111 Share on other sites More sharing options...
July 4, 20205 yr comment_602116 The mast will come apart the tip of the antenna is screwed on take that off and you can slide the attenna apart. The threads are small so use a little heat on the tip to loosen a little. I took mine apart to replace the string see the link. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602116 Share on other sites More sharing options...
July 5, 20205 yr comment_602137 Making a mast tip from scratch should be a relatively easy task on a lathe. I might be convinced to give it a go if someone has a sample to use as a pattern. As for getting the mast out of the body, all I can do is assure you that there's nothing holding it in other than corrosion. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602137 Share on other sites More sharing options...
July 5, 20205 yr comment_602144 11 hours ago, Captain Obvious said: Making a mast tip from scratch should be a relatively easy task on a lathe. I might be convinced to give it a go if someone has a sample to use as a pattern. I'll put one in the mail for this endeavor tomorrow Cap'tn. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602144 Share on other sites More sharing options...
July 5, 20205 yr comment_602148 13 hours ago, Captain Obvious said: Making a mast tip from scratch should be a relatively easy task on a lathe. I might be convinced to give it a go if someone has a sample to use as a pattern. No charge I imagine. He works on tips, like a mohel. Edited July 5, 20205 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602148 Share on other sites More sharing options...
July 6, 20205 yr comment_602195 LOL. I tried to find the old SNL spoof ad where they circumcised a baby in a car to illustrate the smooth ride. But SNL has clamped down pretty hard on copyright stuff and I couldn't find it. Zup, I'll keep my eyes peeled. Link to comment https://www.classiczcars.com/forums/topic/46443-antenna-rebuild-restore/?&page=9#findComment-602195 Share on other sites More sharing options...
