Gav240z Posted November 22, 2021 Share #121 Posted November 22, 2021 Hi Folks, I may have found a source for arrow tip antenna pieces. https://www.ebay.com.au/itm/173930578522?hash=item287f12025a:g:LoEAAOSwh7ZdAEU3 Seller: https://www.ebay.com.au/usr/bozzas5?_trksid=p2047675.l2559 I've just ordered 1 on a bit of a punt, will see when it arrives how good it is or close to original. Even though I'm not missing the tips on mine, I have more than 1 240z in need of an antenna and may come across a broken mast/missing tip (common). So this could be helpful. 1 Link to comment Share on other sites More sharing options...
hiyabrad Posted December 12, 2021 Share #122 Posted December 12, 2021 On 11/22/2021 at 4:49 AM, Gav240z said: Hi Folks, I may have found a source for arrow tip antenna pieces. https://www.ebay.com.au/itm/173930578522?hash=item287f12025a:g:LoEAAOSwh7ZdAEU3 Seller: https://www.ebay.com.au/usr/bozzas5?_trksid=p2047675.l2559 I've just ordered 1 on a bit of a punt, will see when it arrives how good it is or close to original. Even though I'm not missing the tips on mine, I have more than 1 240z in need of an antenna and may come across a broken mast/missing tip (common). So this could be helpful. Any update? Link to comment Share on other sites More sharing options...
Gav240z Posted December 13, 2021 Share #123 Posted December 13, 2021 Yes, the tip is a bit bigger than the OEM S30z version. It has a thread at the bottom for screwing it onto the mast but I haven't tried it to see if it's the right size. So it depends how fussy you are re: exact size. Link to comment Share on other sites More sharing options...
