Email logins are now active ×
diff. questions
i been looking at a r180 with the 3.9 ratio from a 720 truck 4x4 . will it direct bolt in to my70 240z? or do i need new shafts . this one has bolt flanges.
i am going with l28 and want to make the best of it. i am going with the 4 speed for now although i have 5speed from a 83 zx . but from what i read i should not use it.?
any ideas would be helpful.
thanks
dan
If you put a 3.9 differential in the car you will need the 83 5-speed, at least on the highway.
I cannot answer the question about the halfshafts, but a L28 with the 83 5-speed and a 3.9 differential is pretty much the hot setup for all Nissan parts.
Good motoring!
i have a 70 that has a long way to go. i wasnt sure which way to go and this one came up. they are hard to find . i hope that i made the right decison . i went with the 720 because it sounds a lot easier than to have to scource out all the parts for the r200. all said and done the cost was about the same . 4.11 give you more bottom end? is it a direct bolt up? it is a r180?
i found a 4.11 bolt in . would it be worth it to pick it up and try to sell off the 3.9 . it is going to to be a weekend street machine . think i would notice a difference between the two? tried to find the ratio caculator but it was gone.
  • Who's Online   2 Members, 0 Anonymous, 686 Guests (See full list)
