Posted May 3, 201311 yr comment_422369 Please see the attached picture. Is the item I circled in red the vacuumcock? I'm trying to find were the hose coming out of the top is supposed to connect too (identified with the red arrow) I'm looking at the AC FSM for a 1974 260z, mine is a 1975 280z. I'm thinking it could also be a check valve on page AC-34. Kind regards, Robert Link to comment https://www.classiczcars.com/forums/topic/46447-vacuumcock-identification-verification-request-1975-280z/ Share on other sites More sharing options...
May 3, 201311 yr comment_422377 The 74 260Z is carbureted and the 75 280z is fuel injected so the two are not similar enough to comare for your purpose. Get the correct manual. You should be able to get the one you need here: XenonS30. Link to comment https://www.classiczcars.com/forums/topic/46447-vacuumcock-identification-verification-request-1975-280z/#findComment-422377 Share on other sites More sharing options...
May 3, 201311 yr Author comment_422401 That is where the manual came from. If you look at the site you'll see AC is missing from the 1975. There is no other choice but to look at the 74's or 76's at least on that site. Link to comment https://www.classiczcars.com/forums/topic/46447-vacuumcock-identification-verification-request-1975-280z/#findComment-422401 Share on other sites More sharing options...
May 3, 201311 yr comment_422427 Looking at a '76 would be a much better choice. Link to comment https://www.classiczcars.com/forums/topic/46447-vacuumcock-identification-verification-request-1975-280z/#findComment-422427 Share on other sites More sharing options...
May 3, 201311 yr comment_422450 I've seen those on the 280zx's. Maybe try one those manuals. Link to comment https://www.classiczcars.com/forums/topic/46447-vacuumcock-identification-verification-request-1975-280z/#findComment-422450 Share on other sites More sharing options...
