Two black & one green wire/ solenoid on 72 240Z Auto.
jed
Thanks for your replies.
I've attached two further photos, the relay is saying 'Horn'. Maybe it's part of the manufacturers name?The battery has died on me again so I can't check if its still working. That said, it wasn't working as the internal had been removed but I could short it out for it to work.
The kickdown solenoid appears to be on the front section of the auto box.
The horn relay uses different coloured wiring.
I haven't spent much time on it today, the sun came out so I took the bike out.
I think I'll have to do the checks as you suggest and see if my horn still works. You may know the effort it takes to change a radio with having to disconnect the heater controls so I'll try and get to the bottom of it before I put the Radio in and avoid having to take it out again.
Thanks again.
