Fentin_Fury Posted February 10, 2003 Share #1 Posted February 10, 2003 I have a '72 240Z with a Crane XR3000 ignition system. Everything functions fine:classic:. I upgraded over the weekend with the addtion of a Crane HI-6TRC. Now the tach does not function:cry: . Does anyone out there have expereince with the 240Z type distributor and the Crane HI-6? the HI-6 does have a "tach output" but I do not believe this is what the 240Z tach requires. Any suggestions appreciated. Link to comment Share on other sites More sharing options...
kmack Posted February 10, 2003 Share #2 Posted February 10, 2003 This is information posted off the emial list a few years ago. Hope it helps.- -- Group Message from “Little Flyers Tim†<tim@littleflyers.com> --Hey Cary,I suggest you install the 6000-8920 (not 6000-8910) with the secondwiring diagram http://64.90.9.168/cranecams/pdf/90008920.pdf . Use this oneif you did converted the points to an eletronic system and want to keep theearly tach.Tim 71 240Z Link to comment Share on other sites More sharing options...
Fentin_Fury Posted February 11, 2003 Author Share #3 Posted February 11, 2003 great! I new a "tach adapter" was necessary but not which one.thanks Link to comment Share on other sites More sharing options...
