Email logins are now active ×
Horn Pad
frankensteinZ
The Horn Switch mounts on the steering wheel center and uses the steering wheel center as part of the circuit.
The Horn Pad clips onto the Horn Switch Contact Ring.
You could actuate the Horn by pressing on the Contact Ring until it makes contact with the Steering Wheel Center WITHOUT the Horn Pad, but some people might feel a small shock.
2¢
Victoria British does not show that part separately.
Neither does Motorsports.
You ~might~ be able to find it at a boneyard, but it might be easier to get the whole steering wheel and cannibalize it. Usually, when you get the steering wheel they include the horn switch with it.
Hope this helps.
