Posted May 13, 201311 yr comment_423349 Hey guys, in the process of getting my 240z ready for the road, I realized it had no side mirrors, so I bought a new one, specifically, a new-in-box OEM flag mirror. While looking it over, I noticed this little defect, which you should be able to see in the picture. I can see how it could happen when folding over the edge, and I can see how it would be hard to avoid, but is it 'normal?' Or should I send it back? This may be a silly question, but thought I'd ask. This is mine: This is another pic I found on here, looks like it might have the same defect, in the same place (outermost edge when mounted), if you look at the one on the right. Thoughts? Edited May 13, 201311 yr by rturbo 930 Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/ Share on other sites More sharing options...
May 14, 201311 yr comment_423359 It's hard to tell what's going on from the photo. Is it a flat spot or a change in radius? Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423359 Share on other sites More sharing options...
May 14, 201311 yr Author comment_423360 Oiluj said: It's hard to tell what's going on from the photo. Is it a flat spot or a change in radius?Both. Seems that when the backing was bent over the mirror glass, part of it was pressed too much, creating a flat spot, and also pushing the metal out. Let me see if I can get a better pic.Edit: Haven't been able to get a pic that shows it any clearer. It's admittedly a really small defect, and pretty trivial, but it still bothers me. Edited May 14, 201311 yr by rturbo 930 Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423360 Share on other sites More sharing options...
May 14, 201311 yr comment_423366 Yup. I went through 3 mirrors before I accepted that flat spot as "normal". The last one I settled on wasn't so drastic though. I also noticed that all of them had small "normal" defects on the short edge where it looked like the metal was hammered to fold over the side on to the glass. I don't have the mirror on me right now but I can sent you a picture on Wednesday.Matt Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423366 Share on other sites More sharing options...
May 14, 201311 yr Author comment_423368 Yeah, I wouldn't mind a pic for comparison. I'm building a driver, not a top notch resto, so it's not that big of a deal, just kind of annoying considering I bought it brand new, and I wouldn't say it was cheap. If it's a common problem, I may just accept it, but I have another 10 days or so to think about it... Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423368 Share on other sites More sharing options...
May 14, 201311 yr comment_423380 Ya I felt the same way. I'll take a closer look on Wednesday but I'm pretty sure mine was the same.Matt Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423380 Share on other sites More sharing options...
May 15, 201311 yr comment_423488 Hi Owen. Attached are pictures of my mirror. It has the same mark that you have Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423488 Share on other sites More sharing options...
May 15, 201311 yr Author comment_423497 Thanks for the pictures, Matt. That's odd that it's such a common problem, but I guess I'll just keep my mirror. I won't notice it 99% of the time anyway. Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423497 Share on other sites More sharing options...
May 21, 201311 yr comment_423900 I wish there was a passenger side version of the original mirror. Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423900 Share on other sites More sharing options...
May 21, 201311 yr comment_423902 Why can't you use it for the passenger side? The mirror flips all the way around I believe. Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423902 Share on other sites More sharing options...
May 21, 201311 yr comment_423903 The mounting base is angled to fit the left side.Chuck Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-423903 Share on other sites More sharing options...
June 12, 201311 yr comment_425402 You just need to get a RHD version. Japan, Australia, much of Europe would be good sources. Link to comment https://www.classiczcars.com/forums/topic/46539-bought-a-new-mirror-is-this-defect-normal/#findComment-425402 Share on other sites More sharing options...
