Posted May 16, 201311 yr comment_423523 Pretty sure I had a problem trying to get one of these years ago. I am missing the thremostat housing/water outlet or inlet. Bolts on side of head in front inlet manifold. Can I get one new or is it wreckers only? Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/ Share on other sites More sharing options...
May 16, 201311 yr comment_423532 Do you mean the bypass fitting that goes to the Aux. Air Valve? If you have the required attachment bolts, you could probably make one up. You didn't mention the year of the car/engine. Edited May 16, 201311 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-423532 Share on other sites More sharing options...
May 17, 201311 yr comment_423592 Do you mean this:Motorsport! Thermostat Housings - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z PartsLooks like if you have a 70-72 or a 79 you are in luck. Otherwise... Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-423592 Share on other sites More sharing options...
May 17, 201311 yr comment_423597 I think this guy can help you:Rod's datsun parts San Jose, Ca Office phone: 408-448-3277Office fax: 408-723-0485URL: Welcome to Rods Datsun PartsToll Free: 888-257-7773 Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-423597 Share on other sites More sharing options...
May 17, 201311 yr Author comment_423613 Sorry, thought I put the engine in. It is a 76 240k with standard L24. Think it is a 2 bolt fitting. From memory does seem to be something like Motorsport! Thermostat Housings - The Z Store, Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts (the first option). Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-423613 Share on other sites More sharing options...
May 18, 201311 yr comment_423673 Got mine from Nissan., Part number11061-P0300top outlet side11060-U0100thats via Nissan North america BUT according to my packing slip, ive had these sitting around since 2009.... Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-423673 Share on other sites More sharing options...
October 8, 201311 yr Author comment_433236 Just thought I would share to save anyone else the hassle. Thermostat housing top can be bought from Kilkenny castings #wo26b2 and the base to match mine is wob51. I didn't need to buy the base but 99% sure it will match. Link to comment https://www.classiczcars.com/forums/topic/46557-water-outlet-thermostat-housing/#findComment-433236 Share on other sites More sharing options...
